RCU Forums - View Single Post - E-FLIGHT BLADE CP
Old 03-30-2006 | 06:20 PM
  #2747
CrashinJ
Default RE: E-FLIGHT BLADE CP
How many battery packs did you go thru before you learned to hover?? I'm just curious. I just ran out my 8th pack a little bit ago. I only have a roughly 7ft by 7ft space to fly in the living room(no basement or garage). So far I can manage to hover 1-3 seconds before drifting off and having to set down. With tail in I can pretty much hold it in one place, just keep applying throttle till its pretty much stays in one place, then lifts off. Have not had to replace anything except the blade grips, the rotor blades are starting to show a lil wear tho. Anyway I was curious about the battery packs.
CrashinJ
