Lol on the solo
Unfortuatnly not about switching tx's. The trainer box that is used is a old 4 channel futaba with out a crystal or batterys. Actually I'm not even sure if I saw a trainer switch on it. so no good there
But I called hitec, and they're sending out hte switches tomroow priority mail, so I should get them in a few days. Still fustrating. Boy i've had a day.... may as well give the whole scoop on today.
Well, I finish up with some stuff around the house and decide to go swing by the feild and see if anyones out there. I load up my car, and go to LHS in nashua nh cause I needed to pick up a muffler assembly bolt that somehow vanished. I pick that up and just gonna go straight down rt 3 to the feild. I'm almost past the exit I normally take to go home, and I have a thought.... wasn't I using the sim last night. I grab my tx off the front seat and look down to the big old hole where the cyrstal should be. DOH! So ok, no big deal. Just like 45 mintues more driving time. I go home and grab the crystal. Head back out. Decided to take the highway rather then the back roads I prefer cause it's a little quicker. Now somehow I compleltly space out gettin of 95 and wind up on 3N instead of the middlesex turnpike. Doh! No problem.... I got up a exit and take 62. Not use to coming onto 62 from that directino and wind up going the wrong way. So a u-ee-ing I go. Finally I get to the field. Some cars there. Yay thinks me. I get out of car and go around to pull my stuff out. Pull the wing out, and find out I had crushed the sheeting on the bottom tip of the wing by accident when I shut the door.. GRRRRRRRRRRRRR!!!!! Back home I go. Get the wing fixed, pack up again, and head out once more. Around 3:30 now when I had expected to be at the field at 12:30ish. I finally get the field at around 4. Pull my stuff out again, and drag it all out to the pits. Then I discover the busted trainer switch.... *sigh*. What a day.
