RE: cutting carbon fiber tube
use masking tape and a fine toothed razor saw. the dremel is just going the beat the pucky out of it. ALso cut around the tube and not straight through it. some minor peeling I wouldn't worry about since they would be glued back down when you epoxy the ends on
