RE: CofG Pattern Plane?
Bobro, By all means do the MAC calculations and start out at about 30%-35% point on the MAC line. After you get the CG at this point, make sure it is also forward of the wing high point. This is a safe starting point for the CG. After you fly the plane for a while you can adjust the CG to your liking.
Good luck
Oldbob
