improper idle settings or brake settings?
If you have the stock clutch which lacks a clutch shoe return spring then this is normal. Also make sure that the clutch bell bearings are in good shape and spin freely. The 4 in 1 clutch from MIP has a return spring and works much better at idle and is what most GT owners use. Hope this helps.
