RE: Squealing Diff
Woot, this topic has been brought back from the grave! Thanks for the suggestion, however I solved that problem a while ago already.
I'm not sure if you should use that heavy duty oild stabilizer though, I'm no expert on greasing/lubing but something that "bonds" to the gear may not be recommended in the long run since it may interfere with the mesh. Someone may be able to comment more on it.
