ORIGINAL: H0ndaJunkie
I also notice that my headspeed doesn't appear to be anywhere near what it should be at idle-up......I don't know exactly what it is, because I don't have a tach.
I'm currently running the Align 430L 3550kv motor, with a 25A ESC and the 11 tooth pinion gear. Would I be safe to go up to a 13 tooth pinion with this motor?
You (probably) just hit the nail on the head.
If your HS is too low then the tail WILL wag...
