RCU Forums - View Single Post - Mayhem/CRADDOCK question
Old 03-31-2006 | 11:21 PM
MorganSS
Default RE: Mayhem/CRADDOCK question
alright, I removed the rotors and everything spins okay but I have bare metal pads (I was instructed the craddocks use this) and Im having a tough time getting the linkage right
did you also remove the stock metal shims that slide on the screw that holds the pads on?
did you have to significantly adjust your brake throttle linkage?
I can either get no brakes, or full brakes after starting engine []
