RCU Forums - View Single Post - E-FLIGHT BLADE CP
Old 04-01-2006 | 02:12 AM
  #2770
zooland1's Avatar
zooland1
Default RE: E-FLIGHT BLADE CP
ORIGINAL: Dennis Flora
The Blade CX has a LiPo Battery, but you will have to adjust the time for the extra capacity. I also have the Triton Charger. Best $130.00 I ever spent. It charges everything, but it is only 12 volts, so you need to have a power supply or a battery to operate it on. I use a 20 amp Astron Regulated Supply I also use for my Ham gear. It's a great charger for the money...
I forgot about the 12v. My Maha charger is 110v. My son-in-law uses a converted pc power supply. I also have a 12v converter from an old cash register I use for my rc car charger. It's pretty easy to make a 12v DC transformer from Radio shack parts for less than 20 bucks. I made one for my foam cutter. I also use it to test my homemade brushless motors with different output voltages so I can see what they'll do with different batteries.
