Darrell,
What I would do in this case, is put and accurate centerline on each rib, front to back. Then use an angle finder, incidence meter, etc, to set each center line at the same angle to building board, using the small supports on the ribs.
This may be exactly what you were describing in your previous post. If so ignore this.
