RCU Forums - View Single Post - Older HL's...Pull to left????
Old 04-01-2006 | 03:59 PM
jstrat121's Avatar
jstrat121
Default RE: Older HL's...Pull to left????
ORIGINAL: NEIL M
I know it sounds silly but you will note that like on a real Tiger the track links on both tracks are identical. This means (as with the real Tiger) one set is effectively running backwards.
Try swapping the tracks around so that the backwards facing one is on the other side.....it might help!
Neil
You sure about that?............Cant be done[:-]
