how thick is the shim you used? i have some 2mm aluminum sheets. im planing to just cut two small plates and put it on top of the stock mount, you think thats enough?
ORIGINAL: Jammin101
I am just about finished with my build of a new CRT and am using an OS30 with a pull start. I had to shim the stock motor mount to allow for the pull start to fit. Hope to run it this weekend.
