RCU Forums - View Single Post - Wireless Jet ECU Real-time Data from Eagle Tree
Old 04-01-2006 | 06:41 PM
billpa's Avatar
billpa
Default RE: Wireless Jet ECU Real-time Data from Eagle Tree
Hi All,
WHMC, yes the Gaspar FADEC is fully supported, so if Artes and Wren use the FADEC, we should be all set with them. We have the Merlin in-house.
techjet1, thanks for the feedback. Our system is definitely not for the pilot to watch during flight. The alarms are audible - you program alarms for low battery, low temp/RPM (for flameout detection), stall speed, altitude ceiling, etc. The LCD display is great if you have a wingman during flight, and for run-up - the unit displays basically the same status messages the GSU/EDT displays, which can be helpful.
Note that we interface directly with each ECU, so the support is customized for each ECU.
Bill
