RCU Forums - View Single Post - Wireless Jet ECU Real-time Data from Eagle Tree
Old 04-01-2006 | 09:10 PM
FB111NAV-RCU
Default RE: Wireless Jet ECU Real-time Data from Eagle Tree
Bill,
I have a Jet Cat speed limiter which plugs into the ECU. Will the Seagull system with ECU interface transmit the airspeed readout from the ECU speed inputs from the speed limiter Or will it transmit the airspeed from the pitot static system connected to the Eagle Tree Seagull System?
I want to keep the ECU airspeed inputs from the speed limiter as well as get a readout and audible airspeed tones without using two pitot tubes or putting a Y in the pitot pressure and static tubes if at all possible.
Bob Radford
