RCU Forums - View Single Post - Bulletproofing FunFactor
Old 04-02-2006 | 01:24 AM
  #70
dustin7837
Default RE: Bulletproofing FunFactor
Here are some Pics of the plates I bought off azzman. I had to grind the one down on my mt2 so it didt hit the batt. box for some reason. Also one was cut for the ofna tank and one wasn't when I got them so I cut it down anyway. You can see the Rally one has the stock steering servo mount and also has some holes drilled above the spurs. I think I might drill holes like that on the MT2 plate. They were just a shade too tight when i got em and tightened them down, the center driveshaft was too tight between the diffs. I just rubbed then ends of my driveshafts on a file so that I took off about half a mm on each end and it fits PERFECT now.
I wasn't able to get a JT chassis so this is the next best thing.
Pretty hard to bend a chassis now...
PS: The MT2 is as ugly as could be, but its about as solid as it's gonna get unless those alum diffs work out
and I'm still waiting for my front buggy shafts [:@]
ID:	437402   Click image for larger version
ID:	437403   Click image for larger version
