RCU Forums - View Single Post - Wild Hare Ultimate CG
Old 04-02-2006 | 07:40 AM
flyrccg
My Feedback: (25)
Default RE: Wild Hare Ultimate CG
Thanks Airborne, I am using a MVVS 58 powerhouse. I have 2 of these my other is on a WH Edge and will hover at 1/4 throttle and pull up out of sight like a rocket at 3/4. The only problem with this plane is if I need to CG past 6 1/2", I will have to add dead tail weight because I've moved everything to the tail already. Where did you start your CG for maiden and did you move it later?
I will be retiring the Edge and using that 58 for a 33% TOC Yak that I plan to buy at Joe Nall.
