RCU Forums - View Single Post - U Can Do 3D
Thread: U Can Do 3D
Old 04-02-2006 | 08:38 AM
  #2944
AcroJo's Avatar
AcroJo
Default RE: U Can Do 3D
StevL, Dubro # 867 HD Control Horn. HD Ball Links # 899 and Safty Lock Quick Links #817. Pull/Pull on rudder is #880 If a cable setup is desired then it is #881
Currently with servos sent back to Horizon for repair, I temporarilly installed slightly heavier elevator servos. To offset the weight I eliminated the 4/40 steel linkage and made up CF rods with 'aluminum' all thread. Much lighter than steel all thread and the CF supplies all the integrity needed. Will swap out the rudder today hopefully. Either CF linkage or cable. Weather looks promising for this afternoon. Joe
ID:	437479   Click image for larger version
