RCU Forums - View Single Post - MVVS/Evoloution 58
Old 04-02-2006 | 04:45 PM
pe reivers
Default RE: MVVS/Evoloution 58
The center bolt is flanged, and holds the prop drive on the taper, so it cannot be safely removed.
If the mounting screws are not tightened regularly, the M5 bolts may be asked upon to provide the drive torque. Noty being disigned for that, they then will break, and if they do, the central nut will keep the prop on the hub.
