RE: 9C Programming Problem
Thanks for the input but the flaperons are enabled!
Here is what the computer is saying:
PROG.MIX3 1/2
(ON)
(AILE-FLAP)
RATE <- ->
0% 0%
OFFSET 0%
PROG.MIX3 2/2
MIX > ON
MAS > AILE
SLV > FLAP
LINK > OFF
TRIM > OFF
SW > G
POSI > DOWN
I think I've tried most combinations but I would be more then happy for some input. Again, currently the left aileron is functioning but only at about 50% throw even with servo stops at 100%. The right aileron only works if using VRa and it has full swing.
I doublechecked both AIL-DIFF and ELEVON to make sure they were INH. They are. Thanks again.
Bruce
