RCU Forums - View Single Post - TX RX matching
Thread: TX RX matching
Old 12-14-2002 | 11:00 PM
Cleared4Crash
Default More info
I found additional info on the subject at other posts on RCU. I
will put it here as a follow up.
The way I understand it is that the TRANSMITTER's frequency
module electronics need to be tuned to it's crystal. It's OK to
swap out entire modules but not OK to change individual
crystals.
RECEIVERS however do not need to be so finely tuned; therefore
you are allowed to change crystals.
I believe the reasoning is that out of tune transmitters can
interfere with other channels and other planes but an out of
tune receiver won't cause interference because it doesn't SEND
out any signals.
The exception being you can't mix a PCM receiver with a non-PCM
transmitter. Some transmitters however, can be either PCM or
plain FM (non-PCM) so those may be used with both types of
receivers.
You're misunderstanding matching. Matching is when someone
sends us their transmitter and receiver both. We tune the
transmitter to its maximum output, adn then tune the receiver
to the best possible reception of this transmitter. This is
done only rarely and is usually done for high $$ specialized
aircraft htat are having noise interference problems.
you can change your receiver channel at any time by changing
crystal as long as you stay int he right half of the band
(11-35 or 36-60); you are not supposed to change your
transmitter crystal at all except to replace one which got
damaged, for example, when dropping a transmitter.
