OK, You have two mixes that is needed.
Turn off the PM3.
Turn on the Flaperon
That should allow 1 and 6 to move.
Use the Nor/Rev selection for each channel to get it to move in the right direction.
Next go to the spoileron enable it.
YOu need to adjust the rate direction to get the surfaces to move in the direction that you want.
None of your PM are needed to do this.
ORIGINAL: Bruce Bennett
Thanks for the input but the flaperons are enabled!
Here is what the computer is saying:
PROG.MIX3 1/2
(ON)
(AILE-FLAP)
RATE <- ->
0% 0%
OFFSET 0%
PROG.MIX3 2/2
MIX > ON
MAS > AILE
SLV > FLAP
LINK > OFF
TRIM > OFF
SW > G
POSI > DOWN
I think I've tried most combinations but I would be more then happy for some input. Again, currently the left aileron is functioning but only at about 50% throw even with servo stops at 100%. The right aileron only works if using VRa and it has full swing.
I doublechecked both AIL-DIFF and ELEVON to make sure they were INH. They are. Thanks again.
Bruce
