RE: Monokote
I have too agree with the quality problems. I have been using Monokote for years and have always had good luck. The last few rolls I have used were very poor. The colors were off ALOT from one roll to the other. I have never had a problem with color matching in the past. Also if putting on over a solid surface, it looks like there is sand under the covering. On my last model, which was a 1/4 scale so I needed several rolls of covering, the old stock that I had on the shelf worked great. The problem came to life when I purchased the new rolls. Half my model looks great, the other half very poor. You could see the difference in the covering the minute you took it out of the wrapper. Just my two cents worth
