RCU Forums - View Single Post - Wireless Jet ECU Real-time Data from Eagle Tree
Old 04-03-2006 | 12:02 AM
billpa's Avatar
billpa
Default RE: Wireless Jet ECU Real-time Data from Eagle Tree
Hi Bob,
Yes, we can do that. However, there may be some advantages to using "t" fittings with the existing pitot/static lines:
1) the airspeed on the Pro is very high resolution - I don't know what the res is on the jetcat airspeed (it could be just as high). However, it's important to have high resolution for good low speed measurement.
2) the sample rate on the Pro sensor may be higher, and it has sophisticated temp and other compensation (again, the jetcat airspeed may well be just as good, as JetCat is an excellent product in general - I don't know)
Also, there is no technical downside to using T fittings that I am aware of, aside from the headache of the additional plumbing.
Bill
