Can be done, however SCAT has a battle field already and in use
As far as the pull to the left, check the road wheels and see if some drag, their has to be a reason, something draging, try putting the tank on a 2x4 so the tracks clear and run it watch for track alignment any kind of binding. maybe the sprocket teeth are not catching the tracks properly.
Merle
ORIGINAL: jstrat121
The links are exactly the same (in number of actuall links). All gears seem to be OK, no binding at all.
S.C.A.T. is hard to get anything done with......slow on e-mail reply[&o]. Maybe we should form our own tank corp?
