RE: More power
You should/could be using 10-15% nitro. Going to a higher percentage will be harder on the engine without a significant power increase.
What prop do you have on the engine? A 10x6 is common in that size engine. A 10x7 would give a little more speed but you would sacrifice some of the vertical ability.
