RE: Starter Plug-in
Still no luck finding these things. Another simple solution is to go to Radio Shack or just about any car parts store. Buy a couple heavy duty inline connectors. Cut off the gator clips, leaving about 10 inches of wire with the clips. Solder one end of the connector to the remaining starter wire and the other end to the wire that's attached to the gator clips. Then part of a second connector and some wire to make a second set of leads with banana plugs at the end. If you feel your starter wire isn't long enough, you can make the leads longer at the same time.
