RCU Forums - View Single Post - 16lb of thrust on 42cc
Old 04-03-2006 | 08:09 PM
Ralphbf's Avatar
Ralphbf
My Feedback: (27)
Default RE: 16lb of thrust on 42cc
Let's see.....
Smaller APC prop.
Bigger carb better exhaust.
If this was a chain saw You should have a working rpm of 10,000 rpm.
If it was a blower then around 8,000.
A 16 x 8 APC prop at 10,000 gives around 19 lbs of thrust.
A 17 x 8 APC prop at 10,000 gives around 25 lbs of thrust
Both of these numbers require less than 5 horsepower.
So you should prop to run in these rpm ranges.
I had a Stihl 088 that ran 13,000 rpm. It had a bored out carb, hollowed out muffler and about .025
milled from the base to raise the compression and raise the port height.
It was very fast.[sm=biggrin.gif]
