ORIGINAL: Stickbuilder
Makin it easy to find.
I'm working on a new question regarding a OS 61 max SF motor w/ pump, I'm having a hard time keeping it going it keeps stopping can't move the throttle any direction too fast as it seem as it does'nt have enough gas or maybe too much, the motor is a 1986 OS, has not run for a long time, although it turns real good and has good compression, I remove the line from the carb feed to see if the pump was working, and it seem to be working, one time while trying to start it the gas was coming out the pits muffler and pooling on the ground, I only turned the high speed needle so far as I was told when it was last run it was
running real good, there are more adjustments valve, but I did not want to mess with them yet , it might need a good line and carb cleaning??? if you have any experience with this motor, I would appreciate all the info I can get. I will try again so I can note more information to note.
roltech
