RE: Micro Turbine Bench Control Unit.
I have one, yes, identical. I will throw it in if you want. The Reaper needed two seperate boxes, the fuse box is not closed yet. Purolator should pick them up this week, I will let you know when they do.
Did you get an ECU with this engine you are talking about? You can't fly the thing with just the Bench Control Unit thingie. Did you get a starter wand, too?
