RCU Forums - View Single Post - 9C Programming Problem
Old 04-04-2006 | 05:43 AM
Geistware
My Feedback: (16)
Default RE: 9C Programming Problem
No mix is needed. Use the Airbrake function and you can mix elevator flap automatically.
ORIGINAL: MikeEast
If you are wanting to use true flaperons... I would just use an elevator to flap mix. Play with the rate numbers to get the desired effect. Im looking at it on my 9C right now and its about as simple of a mix as you can get.
