RE: Attack of the Clones
Someone asked me about the Elevator set up. My had four pieces of wood that are to be used as bushings or something. I am problably going to trow them out and use two brass bushing in there. One to support the actual elevator arms and one to support the elevator machanism. Mine elevator machanism has two hex screws to hold each elevator rod. I just inserted a 1 inch 4-40 screw throught the middle for use as a control rod. Maybe a longer would be nicer, but that is what I had laying around already. Anyway Ailerosn are in and adjusted, I made sure I get at least 3/4 inch travel on each, they are programed into the radion. Flaps are adjusted and programed into the radio, Although I really don't think I will use them much, they have a almost two inch travel. Other than that, just started work in the canopy. Not going to get a chance to do anything on it today, so well see what shows up tomorrow.
Turbulence
