Props...
What glass props are you using that cut your hands? I use the plastic ones (APC) on my smaller 40 size planes and I spend quite a bit of time with each one and a razor blade to make both leading and trailing edges very dull. I tell the newbies to always do this because if you do get hit, it will help to lessen the damage, and you will be able to flip the prop without cutting yourself.
