RCU Forums - View Single Post - Props...
Thread: Props...
Old 12-12-2002 | 03:25 PM
banktoturn
Default Props...
When they're spinning, they can hurt you whether they are sharp or dull. When they aren't spinning, it's pretty easy to avoid being cut. Aerodynamically, the sharper the trailing edge the better. Knock off the flashing, keep the trailing edge as sharp as is practical, and use an electric starter if you need to. The prop is used to fly the plane, and should be optimized for that purpose.
banktoturn
