RCU Forums - View Single Post - Check your shocks !!
Old 04-04-2006 | 09:12 PM
AJsToyz's Avatar
AJsToyz
Default Check your shocks !!
I got the new steering arm for my car and installed it !! After a few miner adjustments I've got the to-in looking good. Then I noticed a little thing with the shocks looked wrong. The little cap that holds the oil seal < I think> for the shock is off. Well it was off on three shocks. You can get them back together without taking the shocks off. Pull the spring up from the bottom to get the cap started , then take the little seat that the spring rides on from the bottom out and you can pull the spring down far enough from the top to tighten it. Of course re-install the little seat in the bottom when done. I don't have my instructions in front of me to see if they hold oil or not , but they are together.
