RCU Forums - View Single Post - Range Check
Thread: Range Check
Old 04-04-2006 | 11:24 PM
Flyjets's Avatar
Flyjets
My Feedback: (51)
Default Range Check
Hi Guy's
Having some troubles with a Range Check was looking for some help with Antenna locations.
The Fuselage has more Carbon Fiber in it then anything we are all used to. I am now isolating the individual servos to see if there is a noisy one.
I'm using dual Futuba 1024 receiver's and routing the antennas in small tubing inside the Fuselage. But my Range checks with the 14MZ Transmitter is only 25 feet no Transmitter Antenna or 50 feet with the Antenna mounted in the Transmitter but not raised.
I want to know if anyone has solved this problem by using either a base loaded Revolution or Whip style.
Ian
