RCU Forums - View Single Post - Range Check
Thread: Range Check
Old 04-05-2006 | 12:49 AM
rorywquin
Default RE: Range Check
A whip antenna will lift you reception away from all the interference in the fuselage which has several wires running in the same horozontal plane. It is never a good idea to run your receiver aerial in a straight line.
