RCU Forums - View Single Post - Range Check
Thread: Range Check
Old 04-05-2006 | 05:57 AM
Silver182's Avatar
Silver182
Default RE: Range Check
ORIGINAL: Flyjets
Hi Guy's
Having some troubles with a Range Check was looking for some help with Antenna locations.
The Fuselage has more Carbon Fiber in it then anything we are all used to. I am now isolating the individual servos to see if there is a noisy one.
I'm using dual Futuba 1024 receiver's and routing the antennas in small tubing inside the Fuselage. But my Range checks with the 14MZ Transmitter is only 25 feet no Transmitter Antenna or 50 feet with the Antenna mounted in the Transmitter but not raised.
I want to know if anyone has solved this problem by using either a base loaded Revolution or Whip style.
Ian
Do a range check for each receiver... without anything else.. just a battery and servo or two to find the Baseline stripped range of the receivers themselves. You should get about 200 paces or 600 feet, with the transmitter antenna mounted and collapsed (7 inches). Receiver antenna's up off the ground about 3 feet. If your range is in the ballpark you then can bring in other components of your setup one at a time to find what is killing your range.
Example start with your carbon fiber mount.. see which device is causing your really bad range check. If your stripped Baseline is not at least 500 feet (166 paces) get the receiver's and or your transmitter module tuned an aligned. Keep in mind a weak transmitter module is possible. Ooops almost forgot you do have the transmitter modulation (page 27 14MZ manual) set properly to transmit to your PCM1024 receiver?
Lee H. DeMary
AMA 36099
