Thanks happywing!
As to the batteries, I have to learn a lot abot those. I have a number of questions:
What is the difference between lipos and the others?
Also, I saw that the conversions made by you and others used two packs of 6 cells each. Is this correct? I assume 1 pack of 6 cell will not last long enough? Why not using 4 packs of 6 cells, then? Too heavy?
Also, what is the run time you are getting with yours? WHat charger are you using, and would I be able to recharge two packs in my car while using two packs in my buggy, so, that I can keep running for a while when not at home?
Again,thanks a lot!!
