RE: ZDZ 40BS engine problem
Sounds like you might have a blockage in the pulse hole of the carb. insulator block. In the block or the gasket slipped to partilly cover the hole. Without a clear passage the carburator cant pump fuel. I would check this first. Hope this helps, Wayne M.
