RE: Covering question...
With a very small stick model like you have I would suggest useing the tissue paper or Silkspan. You will have to apply both with dope, check with your local hobby shop and they can help you out. The covering and finishing process can sometimes take as long as the actual construction. I tend to treat each task as a seperate project especially on large projects.
Good Luck!!
Anthony
