RE: Timing on ZDZ40RE
Hi, I have just bought the Razzia from Topmodel CZ that has the same fuselage of the Aggressor but a funfly wing.
I'm thinking to use a ZDZ 40 RE like you did in your model, can you give me some info about power.
Do you think the 40 RE is enogh power for the model, I believe my model should come out at no more than 6 kg, is the pull out from the hovering just ok or it is very good ??
I'm planning to use a KS 86-4 canister, that should help a little.
Can you give me some measure for the header ?? Looking to the engine on a side, I need the distance from the center of the exhaust port to the engine axe (shaft),
because I need to calculate the drop needed by the header.
Do you have a video of your model flying with the ZDZ 40 RE ??
Regards
Gianluca
Rome - ITALY
