RCU Forums - View Single Post - Glow Plug Question
Old 04-05-2006 | 07:51 PM
majatoi
Default RE: Glow Plug Question
Okay... uhm, I got it so I can brake now and the engine don't die off by increasing the idle... but if I let off the brake the car still runs off on me, not hauling off but enough to make have to go fetch it after if I let it go for about 5 secs.
I am assuming I should adjust the max first then go back and adjust the low rpm needle? Will the low rpm needle allow this rc not to move once I adjust it? I have tried lowering the idle, but when I hit the brake it dies. So this is as close as it gets for the idle being lean I fear.
