RCU Forums - View Single Post - grrrrrrrrrrrrr
Old 04-05-2006 | 08:12 PM
striderjg
Default grrrrrrrrrrrrr
Well, I finally got my blade cp I purchased of ebay. The seller mis represented the item. He had the condition as New in box. I Knew it wasn't nib from the description, but I was expecting from that, that it would be in good condition
this auction is for 1 blade cp
also included is a 1320 mah lithium polymer battery (lipo) or (lipoly) and charger this allows much longer flight times and Way higher blade rpm
has the complete aerobatic enhancement kit installed on it, ie motor, heatsinks, battery, symetrical blades, bell hiller upgrade as well as the aluminum swashplate.
she will fly steady and level out of the box original box package and instruction manual you get with it as well as a ton of spare parts
Pulled it out today, and while yes, original box, NOT original packaging. Just hte box. No styrophm. Whatever. Then I see the canapys. Both are in sorry shape. Next thing I notice, broken skid. no problem, there where spairs in the box. Next, badly bent main shaft. Next, frame snapped off at the 4-1 mount. Hacked fix by using one of the canapy mounting rods glued to the forward petruding parts of the skids. Ca bond had failed. Next, the charger included was the std nimh charger. NOT a lipo charger as the ad seems to indicate. This thing was definatly NOT flyable out of the box and was definatly not in nib condition. I plugged it in and atleast all the electronics seem ok. But the setup is attrocious, maybe due to the bend shaft. I went to hobby shop, picked up a new main frame, and main shaft, and a lipo charger. Tonight I get to rebuild, and send a e-mail to the seller. Argggg, y can't ppl be f*** honest.
-John
