RCU Forums - View Single Post - Antenna question
Old 04-05-2006 | 10:07 PM
bigtim
My Feedback: (13)
Default RE: Antenna question
how about route the wire out the top of the fuse behind the canopy and attach it to the tail using a servo arm piece and rubber band to a pin method like bubba mentioned then any extra is hanging above the ground and your problem solved where you exit the fuse use fuel tubing to protect the wire from chafing on the fuse another way of dealing with your antenna
