RE: Rogue 3D Bipe
The Rogue comes with a plywood mount that you have to build for the OS .15LA motor. It does not come with a fuel tank. Most of the hardware is adaquate for nitro flying. The control horns are red anodized aluminum. The plane is set up for the electric install for the most part. You will have to spend some extra time fuel proofing it, and beefing up certain parts like the firewall, and landing gear.
There are no mounting brackets for the throttle servo, so you will have to make one. There is plenty of space inside the fuselage for a fuel tank. 2-4oz should fit fine with some minor modification.
The motor mount is set up for a horizontal motor install, cylinder head to the right. I think a inverted install would look better, and would eliminate the need to cut the cowl alot.
