NVSFlyer - thanks I was going to try that only my TX (Eclipse 7) only allows negative trim on the throttle channel. To do that i would need of A LOT of positive trim (around 50% of the entire throttle range.[
] Any more suggestions?
Motions - yeah, I'm only using the 0, 25, 50, 75, 100 curve to program the Jazz and so as i can find the correct throttle-RPM setting.
The plan was then to use a 0, XX, XX, XX, XX 'curve' (XX being the throttle % that equates to my desired RPM) for NORMAL hovering mode. Are you saying that pilots that use a GOV always fly in IDLE UP 1 minimum ie. never in NORMAL, which would mean that they always land with a 2500+ head speed[X(]? As I said in my previous post, I'm still in the 'learning' stages which leads me to be a bit apprehensive of landing/crashing at 2500+ RPM. I'd much prefer to beable to cut throttle instantly with the stick. I hope i'm making sense to you.
Thanks guys..........Keep em comin'..........really appreciate the help.........ICE
