RCU Forums - View Single Post - Engine mount install
Old 04-06-2006 | 07:35 PM
redfox435cat's Avatar
redfox435cat
Default RE: Engine mount install
This is a blind nut.
you drill a hole through the firewall big enough for the shank of the nut to go through and is pressed in from the back side/inside of the firewall. the bolt goes through the engine mount into the bilind nut. it hold by nut digging into the wood
ID:	440142   Click image for larger version
