RE: Micro Turbine Bench Control Unit.
Easytiger,
Thanks for the info. I also appreciate you sending along the instructions you have. I will have to order and ecu etc. from JetJoe. I send the engine to a friend to be checked out. He has a balancer. I really want to confirm the engine is balanced before I run it. I understand an out of balance engine can be dangerous.
The one I am getting from you. It was balanced etc. Ran fine? I can't wait to try it.
DW_Crash
