RCU Forums - View Single Post - Beam Designed for P07 from Thailand
Old 04-07-2006 | 02:42 AM
snap_roll
Default RE: Beam Designed for P07 from Thailand
ORIGINAL: psookdee
Well...all i know after i gave them a call is that the whole plane is made from wood and balsa covered with film, one piece wing with adjustable and removable stab. The body of the plane had changed a bit which they moved canopy forward and reduce its size plus a little fin from the top. The main fin shape has changed and the whole body of the plane is some how narrower down a bit. The plane is not mass production, they made it to order...
here is some details about this plane
Length : 1.99 M.
Wing length : 1.88 M.
wing span : 62.15 Sq. Dm.
Engine : 1.40-1.60 (4 Stroke)
OR : HACKER C50 14 XL Gear 6.7 :1
Battery : Li poly 5S4p x 2 packs = 37 Volts.
Prop size 16x14 For YS 1.40-1.60
4-channel 5-Servo (Throttle-1, Elevator-1, Rudder-1, Aileron-2)
Carbon fiber Landing gear, Tail wheel + Control horn and basic accessories
I also post a pix of their latest version....
hi, psookdee, do u have pictures of the modified beam? if so, can u post them pls
