RCU Forums - View Single Post - Help with JAZZ ESC
Old 04-07-2006 | 03:19 AM
iceman101
Default RE: Help with JAZZ ESC
Motions - let me explain. when i say throttle 'curves' i an not literally referring to curves, thats why i write the word in ' '. The apostrophes indicate that the enclosed word is not to be taken literally.
when I say 'curves' i mean either a flat line using equal values within the throttle curve function of my transmitter OR in the case of NORMAL mode which would be 0% at low stick followed by a flat line using equal values via the remaining four points.
In my previous post i have referred to this flat line as a 'curve' . This flat line is what the ESC uses to determine the speed at which the motor should be Governed.
thanks again.........ICE
PS: sorry, i forgot to add the ' ' in the post you quoted
